Date/Time: Wed, 04 Nov 2026 15:52:54 +0000
DVP tool
View Count: 1146
[2021-01-12 01:25:35]
User575399 - Posts: 351
Is it possible to make the tick scale /size default when using the DVP tool to 1. The default is 2. I only want this 1 tick when using the DVP tool please
[2021-01-12 04:26:23]
Refer to:
Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool
[2021-01-13 01:21:59]
I did that . The problem is it keeps defaulting to 2 tick setting
[2021-01-13 14:48:12]
John - SC Support - Posts: 48419
We just ran a test to make sure it is working, and it worked fine for us.
Are you going through all the steps to produce a Study Collection that is the VbP with the Ticks per Volume Bar set to 1? And then setting that Study Collection as the configuration for the Draw Volume Profile?
