Date/Time: Wed, 04 Nov 2026 15:52:54 +0000
Percent Change Option for Rectangle Tools
View Count: 720
[2021-01-11 19:30:38]
User722856 - Posts: 81
Hi Sierra,
Would it be possible to add the Percent Change Option to the Extending Rectangle and normal Rectangle Tool?
Basically, the same logic the Chart Calculator tool has.
It is much clearer to analyse the Chart with an area in mind (=Rectangle) than just a line (=Chart Calculator).
Thank you for consideration.
Date Time Of Last Edit: 2021-01-11 19:31:04
