Date/Time: Wed, 04 Nov 2026 15:52:56 +0000
CQG order execution issue
View Count: 833
[2021-01-11 15:33:00]
Chippstrader - Posts: 31
SC team,
I am using the CQG Web API method for SC connection and trading. I am getting an error where 2 micro contracts are executed but only 1 tgt and 1 stop is in place.
I set Server-side OCO and server-side Bracker orders to NO.
Attached error logs for your review and advice.
Date Time Of Last Edit: 2021-01-11 15:33:12
image2021-01-11_10-28-15.jpg / V - Attached On 2021-01-11 15:32:04 UTC - Size: 721.34 KB - 451 views
[2021-01-11 16:17:30]
Make sure you are using a Time in Force of Day or Good till canceled for the Target and Stop orders and then if that does not solve the issue make sure the Target order is just a Limit order:
Attached Orders: Time In Force
Attached Orders: Order Type (Type)
[2021-01-11 20:35:56]
It worked. Thank you.
