Date/Time: Wed, 04 Nov 2026 15:53:02 +0000
Deseo cambiar mi paquete de servicios
View Count: 789
| [2021-01-11 15:21:58] |
| User892673 - Posts: 1 |
Buen dia soy Santiago Zuñiga Calero y deseo cambiar mi paquete de servicios ya que tuve un error al elegir el actual, quedo atento gracias
| [2021-01-11 17:55:29] |
| John - SC Support - Posts: 48419 |
From Google Translate: Good morning, my name is Santiago Zuñiga Calero and I want to change my service package since I had an error when choosing the current one, stay tuned thanks
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
