Date/Time: Wed, 04 Nov 2026 16:06:27 +0000
VP/NQ
View Count: 820
[2021-01-06 15:36:22]
User00111 - Posts: 111
Two questions:
Is it possible to insert the Volume profile also on NQ? If yes, how do you do it ?
The "Rng" label at the top of the pofile volume does not refer to the Range ..... but what does it refer to?
A.
imageESH21_FUT_CME [CBV][M] 60 Min #6 2021-01-06 15_56_30.335.png / V - Attached On 2021-01-06 15:33:37 UTC - Size: 47.76 KB - 362 views
[2021-01-06 16:29:53]
John - SC Support - Posts: 48419
1. It is not possible to add a Volume by Price profile to a symbol that is displayed using the Add Additional Symbol study. You would just have to create a separate chart for that symbol and add the Volume by Price study to that chart.
2. Is is the range in price from the High to the Low (High - Low).
