Date/Time: Wed, 04 Nov 2026 16:06:28 +0000
Horizontal line for charting only selecting round numbers
View Count: 1104
[2021-01-06 06:10:40]
Timothy Hartnett - Posts: 5
Hi, I am trying to set up my charts for the first time. I just cant seem to get the horizontal line tool to work to create my support/resistance levels. I select the tool and it just picks the closest round number on the scale and wont let me move or adjust it to the level I want. The vertical tool seems to work fine and I assume it is the same process of application so Im just not
sure if there is a setting somewhere I need to change.
thanks.
[2021-01-06 14:45:54]
John - SC Support - Posts: 48419
Refer to this setting:
Chart Settings: Adjust Tool Values to Tick Size (Chart >> Chart Settings >> Chart Drawing menu)
