Date/Time: Wed, 04 Nov 2026 16:06:33 +0000
cannot dowload program
View Count: 719
| [2021-01-05 16:07:35] |
| User962832 - Posts: 4 |
I couldn't reinstall the SC program inside Mainland China after several attempts. Please help to take a look of the log sent. Many thanks! |
| [2021-01-05 16:59:58] |
| John - SC Support - Posts: 48419 |
It looks like you lost connection while trying to get the download. Our recommendation would be use the Zip Installer. Refer to the information here: Software Download: Sierra Chart Zip Installer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
