Date/Time: Wed, 04 Nov 2026 16:19:03 +0000
Allowed systems
View Count: 787
| [2021-01-05 15:15:39] |
| InvestmentCLB - Posts: 11 |
I paid for the SC package 5,and I would like to know can I have one system on my laptop, and another on my desktop? And if so, do I have to pay extra for the data? Thanks.
| [2021-01-05 16:30:16] |
| John - SC Support - Posts: 48419 |
For the Sierra Chart Exchange Data Feed, you can only have one connection active at a time. Therefore, if you are only going to be connecting from one system or the other at any given time, then you do not need to do anything different. If, on the other hand, you want to be able to get the data to both systems at the same time, then the only way to do this for the Sierra Chart Exchange Data Feed, would be to create another Sierra Chart Account and then have that account also have the Sierra Chart Exchange Data Feed. If you would use this setup, we can discount your second Sierra Chart Account. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Connections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
