Date/Time: Wed, 04 Nov 2026 16:19:04 +0000
[Trade Window] Font Issue/Problem
View Count: 1045
| [2020-12-31 02:41:06] |
| SavantTrader - Posts: 112 |
I have two workbooks, and they were problem-free until today. The only thing that happened today was your Denali + Trade offering got activated, and "update chart drawings to current symbol" ran. Even after this, one of my workbooks is fine, but the Trading Panel on the other now shows an incredibly large font for the [C]ompact view panel, and the normal font size for the [Main] panel. Please see the two attachments - they are of the same trade panel; the [C] tab and the [Main] tab. Strangely enough, my other worksheet (with the same symbol) is fine... the Trading Panel font size appears normal for both tabs, as it should. Can you please tell me what's going on and what I should do to fix it? |
| [2020-12-31 03:43:20] |
I was able to "fix" this by simply restarting Sierra Chart.
| [2020-12-31 06:06:56] |
The font size is controllable. Refer to: Graphics Settings: Fonts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
