Date/Time: Wed, 04 Nov 2026 16:19:09 +0000
How to Constantly scan a watchlist in watchlist mode.
View Count: 1370
| [2020-12-30 20:22:46] |
| GravisHTG - Posts: 321 |
I was able to. do the scan on all my ticker in the watchlist , but Each time , It stop after the list. How to make it run all the time till we stop the scan. thanks |
| [2020-12-30 20:56:10] |
You need to enable this menu option: Chart Menu: Enable Continuous Scanning (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
