Date/Time: Wed, 04 Nov 2026 16:31:57 +0000
LANGUAGE PROBLEM
View Count: 940
| [2020-12-30 15:10:11] |
| Laurunrun - Posts: 12 |
i HAVE THE PROBLEM TO USE TRADITIONAL CHINESE TEXT IN THE SOFTWARE ALL THE TEXT WILL BE ERROR. HOW TO SOLVE IT |
| [2020-12-30 19:32:48] |
We will get the traditional Chinese file updated to be compatible with the newer versions of Sierra Chart. We have also added a simplified Chinese language file. Update Sierra Chart to the current version. Instructions: Software Download: Fast Update After the update select Global Settings >> Customize Menu Items. In the Available Preconfigured Customizations select the Simplified Chinese file and then press the Set button. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
