Date/Time: Wed, 04 Nov 2026 16:19:06 +0000
CLOCK
View Count: 761
| [2020-12-30 13:33:18] |
| User00111 - Posts: 111 |
Do not move the text of the time by acting on Horizontal / Vertical Position I am wrong in something ? -- A. |
| [2020-12-30 15:45:51] |
| John - SC Support - Posts: 48419 |
As those Inputs state, they are the "Initial" positions. In order to move the Clock after it has been initially placed, you need to right-click and select Move Drawing. Refer to the information here: Countdown Timer: Moving Countdown Timer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
