Date/Time: Wed, 04 Nov 2026 16:19:02 +0000
i need help.
View Count: 2033
[2021-01-04 21:49:55]
Mr.DaxF - Posts: 47
hello dear support can you please check my account if i activated all right like the behavior from my whish from out this thread?
i will only going secure that all is right!
and thank you for the goodwill help!
[2021-01-04 21:58:50]
John - SC Support - Posts: 48419
Yes, everything looks good now. You should be receiving the Real-Time data now. If not, then let us know and we will check on a few items that could be the cause.
[2021-01-06 07:58:03]
User558884 - Posts: 1
Hello fellows,
I'm trying the Sierra Chart demo and can't login to Rithmic data. Here is the error:
Rithmic Trading | Port for executable: 50816 | 2021-01-06 07:55:31.752
Rithmic Trading | Port for executable: 50830 | 2021-01-06 07:56:07.106
Listening socket (1776). Port 50830 | Closed. | 2021-01-06 07:56:07.106
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-01-06 07:56:07.107
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2021-01-06 07:56:07.107 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. | 2021-01-06 07:56:07.107 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-01-06 07:56:07.107
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-01-06 07:56:07.107
DTC Client socket (0) | CloseSocket call. | 2021-01-06 07:56:07.117
Rithmic Trading | Disconnected. | 2021-01-06 07:56:07.117
Thank you
[2021-01-06 14:48:08]
User558884 - For future reference, please start a new Support Thread for a question like this. It is not appropriate to attach your question to a thread that is not related in any way.
You need to update your Bridge files. Refer to the information here:
Rithmic Bridge Files
