Date/Time: Wed, 04 Nov 2026 16:19:10 +0000
MAC support... when!?!
View Count: 1504
[2020-12-22 18:03:52]
User800642 - Posts: 3
this paralel option you offer is terrible, we need a native mac app...
[2020-12-22 21:20:10]
There are no plans to offer compatibility with the Mac directly.
[2020-12-23 15:50:29]
Really sad, see many users complaining on this forum...
[2020-12-29 17:05:01]
UnixManiac - Posts: 47
Your best bet is to use WINE via third party software. No official SC support though. For me it works great so far.
Hope this helps https://youtu.be/vMNR_8_MwDY
[2020-12-30 03:39:43]
We will be releasing a new version though that supports ARM processors.
Date Time Of Last Edit: 2020-12-30 03:39:48
[2020-12-30 06:19:13]
Da_OG - Posts: 6
From a mac, linux and windows user perspective if you are on a mac just bite the bullet and build a pc to run SC. Parallel, Wine and other options are not any good. I still run a mac and went down this road for months testing things out, ended up just building a high end PC dedicated to SC and it's the way to go.
