Date/Time: Wed, 28 Oct 2026 20:14:28 +0000
Q reg the time & sales window - clarification
View Count: 1037
| [2020-12-21 21:02:43] |
| User101680 - Posts: 11 |
hello, a quick Q reg this Combine Records >> Combine Records with Same Price and Type: Combine Records >> Combine Records with Same Time and Price: Combine Records >> Combine Records with Same Time and Type: ------------------------------------- shouldnt the: Combine Records >> Combine Records with Same Time and Price: not be labeled as Combine Records >> Combine Records with Same Time and Price and Type? or is it possible that Ask & Bid trades are being combined in that option? TIA |
| [2022-02-16 11:44:39] |
| Yuri_T - Posts: 21 |
I would like to join the request with a different, but related question. When we use "Combine Records with Same Time and Price" for TS Window, how is the color of the row based on Type determined? Does it determine type based on delta for same Time and Price? Or does it paint a new row with change of trade type coloring it respectively? I guess I am seeing it is the latter case. |
| [2022-02-18 00:02:52] |
You can control the colors. The color settings are documented here: Time and Sales Window: Time and Sales Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-18 00:03:02
