Date/Time: Wed, 04 Nov 2026 16:38:42 +0000
Scale-In transact
View Count: 868
[2020-12-19 10:22:49]
User308616 - Posts: 4
Hi, I had a problem yesterday with 2 orders each with 2 contracts on 2 different time frames: inserted the first order with its take profit and stop loss, the second in inserting it put the profit at the same point as the first, even if I but I wanted to insert it in a different point (wider) I have already contacted transact who told me it was a problem for sierra and that they could not help me, so here I am.
I am attaching the log and awaiting your reply and above all thank you in advance.
regards
imageProblem.png / V - Attached On 2020-12-19 10:19:48 UTC - Size: 109.4 KB - 401 views
[2020-12-19 20:04:25]
You need to disable Scale In on the Trade Window which is associated with the chart you are trading from:
Attached Orders: Scaling In
