Date/Time: Wed, 04 Nov 2026 16:52:07 +0000
Study 'Daily OHLC'
View Count: 963
| [2020-12-15 18:35:20] |
| User645832 - Posts: 99 |
Hi, I'm using the 'Daily OHLC' on intraday charts. For some reason it doesn't work on Tuesdays, it should show the Monday OHLC levels but instead it shows the Friday levels. It works well on all the other weekdays days. Please suggest what I can do to fix this. Attached are screenshots. Thank you. |
| [2020-12-15 19:51:33] |
| John - SC Support - Posts: 48420 |
Do you have the setting Global Settings >> General Settings >> General 4 >> Use Monday as Start of Week instead of Sunday enabled?
| [2020-12-15 19:52:59] |
Update to the current version of Sierra Chart: Software Download: Fast Update We have corrected some issues with this study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-15 19:54:18
| [2020-12-15 20:04:59] |
it worked
