Date/Time: Wed, 04 Nov 2026 15:52:50 +0000
Not able to trade 6A
View Count: 1759
[2021-01-10 16:24:57]
User377189 - Posts: 216
So when I go into replay and try to place short order, specific date 2020/06/23 @ 10:40 AM EST the order immediately turns into loss
On same time and chart if I goto place a buy order I am able to adjust bracket order
Date Time Of Last Edit: 2021-01-11 11:01:07
[2021-01-10 16:33:19]
Actually even if I do replay on 2021-01-08 @ 9:34 AM EST I am unable to get the bracket order for sell/short order and automatically the order is a recorded as a loss, but if I do a buy/long limit order I do get the brackets that I can move around and does not record an immediate trade
Date Time Of Last Edit: 2021-01-11 11:00:04
[2021-01-11 22:54:29]
It does not surprise us that there is a problem with chart replay. That was not tested and this requires more in-depth code analysis to support this.
See if unchecking this option resolves the issue during a chart replay:
Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu)
If not, the we have to look at this later. We cannot allocate time to it now.
Just remove the Trade symbol when doing a replay.
[2021-01-13 20:58:05]
I unchecked the "Use as trade symbol only" that way only 6A is used in replay.
When I replay 6A for date 6/23/2020 @ 8:40 AM EST and try to short, I do not get the short bracket orders and the trade is instantly recorded as profit/loss
Only when I goto buy limit am I able to get the bracket order and does not directly record the trade as profit/loss
