Date/Time: Wed, 04 Nov 2026 16:51:46 +0000
Study Error - High Low For time Period Extended
View Count: 823
| [2020-12-10 14:23:26] |
| User71961 - Posts: 144 |
This Study "High Low For time Period Extended" is not fully reading the StartTime property for volume based charts I put this study on an ES chart where the candles are 20,000 contracts per bar, with the study StartTime at 09:30:00 EndTime 09:31:00 (so, looking to capture and display the "opening range") And as i sit here at 9:10 am, i see the study high/low lines being drawn on the chart for today's session already (which makes no sense, they should not start until 9:30 am) running SC version 2204 Date Time Of Last Edit: 2020-12-10 16:53:45
| [2020-12-12 22:02:36] |
Disregard the answer previously given. It was not correct. The answer to what you are asking about is explained here: High/Low for Time Period - Extended: High/Low Accuracy You really need to read the documentation first before posting. That is essential. The documentation is very well written. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-12 22:03:09
