Date/Time: Wed, 04 Nov 2026 17:05:23 +0000
Market Profile
View Count: 890
| [2020-12-07 14:23:33] |
| User708888 - Posts: 3 |
Hello, In the Market Profile, I see a chart for the entire week starting on Sunday (29.11.20) and ending on Thursday (3.12.20). That's not right, is it? I have attached two screenshots for this. What do I have to do to fix the error? Thank you Waldemar Lorenz |
| [2020-12-07 16:48:29] |
| John - SC Support - Posts: 48420 |
If you are asking why you only see the particular range of daily TPOs, then that is just the default for what is displayed. You can scroll the chart to see other days, or you can change the time scale in order to see more (or less) data. Refer to the information here: Time Price Opportunity (TPO) Profile Charts: Changing the Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
