Date/Time: Wed, 04 Nov 2026 17:05:00 +0000
CONNECT TO DATA FEED SECOND INSTACNE OF SIERRA CHART
View Count: 755
| [2020-12-01 19:35:08] |
| User341105 - Posts: 20 |
How can I connect the second instance of Sierra Chart to the data feed (AMP)? "Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-12-01 14:05:29.634 * |
| [2020-12-01 19:41:04] |
We see what the problem is. You just need to update that installation of Sierra Chart following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-01 19:42:40
