Date/Time: Sun, 29 Nov 2026 05:26:51 +0000
Customizing the info in the Chart Trading Order
View Count: 763
| [2020-11-24 20:50:13] |
| aelagha - Posts: 31 |
Is it possible to customize what information is displayed in the chart trading order (see image)? I would like to display the stop loss in points/ticks/$$ from entry instead of the SL price. Thx
| [2020-11-25 14:33:56] |
Yes, there are settings for those within Global Settings >> Chart Trade Settings. Also refer to: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-25 14:34:43
