Date/Time: Sun, 08 Nov 2026 08:40:13 +0000
Platform and Datafeed
View Count: 750
| [2020-11-16 15:34:20] |
| gushfx - Posts: 2 |
Hello, I wish to use a trading platform alongside Sierrachart. It seems that I must either use IQFeed data services as both platforms support this feed. The other trading platform also supports ASCII and CSI. Is there a way to use Sierrachart + your data feed and get the other platform to work through ASCII or CSI data? Thanks |
| [2020-11-16 18:49:17] |
Yes possibly. Have a look at this study: Write Bar Data to File This study will export completed bar data to a text CSV file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
