Date/Time: Fri, 06 Nov 2026 06:39:03 +0000
All my stop trades are showing up as stop-limit.
View Count: 759
| [2020-11-12 14:52:11] |
| User548030 - Posts: 25 |
Every time I enter a stop order into the market it becomes stop-limit. So my safety stop is always stop-limit and my stop entry is always stop-limit. In the chart trade settings I have everything set to stop on my bracket orders. Same with the Chart dom settings. |
| [2020-11-12 14:57:38] |
Refer to: Order Types: Stop Orders on the CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-11-12 15:00:06] |
Okay thank you for the referral. I've had price move past my stop and not trigger because it quickly reversed back and I had to exit manually. This seems very concerning. What is your input on this? Doesn't this make trading much more risky if we cannot exit with a stop? |
