Date/Time: Fri, 06 Nov 2026 06:38:55 +0000
Any way to have a watchlist that we can see the % change of each Stock in a Grid.
View Count: 992
[2020-11-11 23:55:55]
GravisHTG - Posts: 321
like a normal watchlist. Check the file for more info.
or anyone know a vendor for this feature ?
Date Time Of Last Edit: 2020-11-12 00:14:19
imageWATCHLIST.PNG / V - Attached On 2020-11-12 00:13:28 UTC - Size: 24.04 KB - 507 views
[2020-11-12 04:38:55]
Use the Quote Board for this:
Getting Quotes
[2020-11-12 11:50:47]
OK, I check this and this is what i was looking for and it now replace my assosiated watchlist window.
2 things now , that i cant find on the help page.
How can we edit .Symbollist from outside sierra chart , because I am copy pasting a list of Symbol that i get from another source. I use notepad right now to import but if i can directly save in .SymbolList It will be better.
Second is , Is it possible to add custom Fields to the quotes list, Like a last 5 min change % , 5 min vol , and so on.
thanks in advance.
Date Time Of Last Edit: 2020-11-12 13:41:09
