Date/Time: Mon, 09 Nov 2026 09:26:15 +0000
Buy Exit Spreadsheet for Target Profit and Stop Loss at the same time
View Count: 2302
[2020-11-11 00:27:29]
User202740 - Posts: 12
I wonder if there's any possibility to trigger a profit target and stop loss at the same time when a buy order is triggered from the spreadsheet.
My aim is to automate a trading strategy based upon the price, so if the candle 1 is the signal candle, I trigger the buy on the candlestick 2 but I cannot find the way to set at the same time stop loss and profit target by using the column L but only one of those options are allowed, am i missing something?
I cannot use the attached orders as there's no offset type based on the candlesticks...
Thanks in advance!
[2020-11-11 04:18:33]
Sawtooth - Posts: 4360
Don't use Columns L/N for this.
Here's one way:
Use Attached Orders to set the target and stop anywhere, then move them to the price you want with the Trade Management by Study study.
Attached Orders: Study Controlled Targets and Stops
Use two instances of the study, one for targets and one for stops, and have each reference a Formula Column (subgraph) where the formula returns their prices.
Here's another way:
Check 'Use Attached Orders' and set the offsets in cells J80/J81.
Note: The offsets are in points (not ticks) from the entry price, and they won't be at a specific price if there's slippage.
