Date/Time: Sat, 07 Nov 2026 09:02:32 +0000
[Programming Help] - Regarding spreadsheet auto trading
View Count: 690
| [2020-11-09 02:42:41] |
| User306531 - Posts: 2 |
Hello! I would like to know if it is possible to have the replay feature go in a continuous loop testing the same time period with different parameters for a trade entry without me needing to start it every time. Example: Lets say I have a breakout setup, that I want to test on the same week but with different requirements to execute an order, like more or less delta, different trading hours, more or less volume, with several different exit criteria, with different brackets, etc. I want the replay software to restart from the same date over and over again without me being there to restart it. Is there such a command i can give the replay feature from the spreadsheet? And if not... Is this solution provided with the ACSIL feature? can you point to any commands for the programming language that does this? Let me know if I should provide more details. Thank you very much for your time! |
