Date/Time: Sat, 07 Nov 2026 09:02:33 +0000
Assigning keyboard shortcut to Reset All Profiles to Standard Profile
View Count: 715
| [2020-11-08 17:20:10] |
| jwick - Posts: 142 |
hmm this is unusual. I have no issues setting other keyboard shortcuts; however, for TPO Profile Chart Commands -> Reset All Profiles to Standard Profile, I cannot assign any shortcut. Hitting the "Assign" Button does nothing. The shortcut isn't assigned / the "Key Currently Used By" field does not update to show any new assignment. On v2182.
| [2020-11-08 21:10:47] |
Thank you for pointing this out. This will be in the next release.
