Date/Time: Sat, 07 Nov 2026 09:02:29 +0000
Reset Defaults not working.
View Count: 1553
| [2020-11-07 19:31:38] |
| m zamani rad - Posts: 24 |
Hi I am trying to change study back to the original after i have made few changes on it since i am not happy and wants the original default but when i click to Rest Defaults and confirm it on next window click ok but I get message STUDY_300.defalutsetting file :windows error code 2:the system can not find the file specified . it happened on different studies. if you know how to fix it please help me . Thank you |
| [2020-11-07 22:03:24] |
This means there is no saved defaults for the study: Error deleting C:\SierraChart\DefaultStudySettings\Study_114.defaultsettings file: "Windows error code 2: The system cannot find the file specified." | 2020-11-07 17:02:07.585 * So the study will be in its default state when you add it again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-07 22:03:45
| [2020-11-07 22:34:49] |
Unfortunately its not in default setting its open as my last satting ( which i made some change on it ). I have tried it by different charts but opened the last one (the one i made it)this is happened to all my studies. i just want to back your format or setting not the one i made . i get same message for all studies. Actually it saved my setting as default and not going back to sierra chart original setting. Thank you |
| [2020-11-08 02:54:43] |
What is the specific name of the study you want to reset back to defaults?
| [2020-11-08 11:15:36] |
I checked it and i was wrong it will open in new charts in original setting . Thank you for your help |
