Date/Time: Mon, 09 Nov 2026 09:38:18 +0000
Problem with Moving Average - Time Period
View Count: 740
| [2020-11-02 20:28:53] |
| Matt NL - Posts: 91 |
Hi I'm trying to set up a 100 Daily Moving Average on a volume chart using the Moving Average - Time Period study. Sadly it doesn't work as the result is incorrect. Even if I use this study on a daily historical chart, it does not line up with the basic Moving Average - Simple study. Is there any explanation for this? Is it not using "simple" moving average? Thanks Matt |
| [2020-11-02 22:15:08] |
Refer to the documentation here, it explains how this study works: Moving Average - Time Period We cannot provide further information. Although we did do some additional updates to that page just now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-02 22:42:19
