Date/Time: Sat, 21 Nov 2026 10:29:41 +0000
Composite Profile (Volume Profile)
View Count: 1273
| [2020-10-31 18:39:18] |
| User956379 - Posts: 27 |
Ladies and gentlemen, how long is the maximum history to load the data for the volume profile? no matter where I set the histoerie to be loaded (chartsettings or in the settings of the volume profile) it will be loaded up to 2019 at most? is there a way to calculate the volume over a longer period? regads matthias |
| [2020-11-02 16:30:16] |
| John - SC Support - Posts: 48610 |
It depends on the particular symbol and the data provider as to how far back the data goes. For the data from Sierra Chart refer to the information here: Sierra Chart Historical Data Service: What is Included For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
