Date/Time: Sat, 21 Nov 2026 10:39:53 +0000
update to 2187
View Count: 660
| [2020-10-28 14:27:14] |
| User863099 - Posts: 8 |
you suggest updating to that version or newer, I updated to that version and my indicators didnt work
| [2020-10-28 14:34:58] |
They may need to be compiled for the current version of Sierra Chart. For now rollback with Help >> Install Previous Version.
