Date/Time: Sat, 21 Nov 2026 10:39:44 +0000
attached order configurations
View Count: 884
| [2020-10-27 02:29:33] |
| MichaelG - Posts: 34 |
is there a way to place an attached order with a trailing stop but only make the trailing stop active after the first target is hit? so for example intial stop is for 3 contracts at 12 ticks....the first target is 10 ticks on 1 contract....once the first target is hit i want the trailing stop to activate an to now be at 4 ticks on the remaining 2 contracts...and be a continuous tick for tick trailing stop to break even. |
| [2020-10-27 02:32:46] |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
