Date/Time: Sat, 21 Nov 2026 10:39:42 +0000
TPO/Volume by Price Request
View Count: 781
| [2020-10-21 20:53:36] |
| User928593 - Posts: 1 |
Hello, I have really enjoyed using SierraChart for my analysis. It is truly one of the best charting softwares I have used. I have 1 request that I believe would improve the software even more. If possible, I would like to request that a separate volume by price chart be built that would have the same functions as the TPO chart where you can form composites. It would have all the same functions as the TPO chart but the profiles would be based on volume rather than time. I know there is a feature where you can use volume on the TPO, but I believe this alternative would be more user friendly as well as being more visually intuitive. I know you have a great team of programmers there so I do believe this is possible to make. I would sincerely appreciate the person responding to submit this to the programming team as a request. Much thanks, Ivan |
| [2020-10-22 06:06:03] |
Have a look at this Volume by Price drawing tool: Volume By Price Study: Draw Volume Profile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
