Date/Time: Sat, 21 Nov 2026 10:47:50 +0000
dax
View Count: 787
| [2020-10-20 21:09:23] |
| User725734 - Posts: 1 |
I am interested in data on the DAX index What is the price per month?
| [2020-10-20 21:17:58] |
| John - SC Support - Posts: 48610 |
This is on the EUREX exchange. Did you require futures data or just the cash index? Did you require real-time data? You would need the Sierra Chart Exchange Data Feed for the EUREX futures data. You will find all the information in the documentation here: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-21 05:24:50
| [2020-10-21 05:24:54] |
Post above has been updated.
