Date/Time: Sat, 21 Nov 2026 10:47:39 +0000
Stop Limit Orders with Transact
View Count: 940
| [2020-10-19 13:39:41] |
| User976943 - Posts: 39 |
Hi, I would like to know if the Buy-Sell Stop limit Orders are allowed with transact, because I have tried using them from the chart but they failed. Please let me know Thanks |
| [2020-10-19 13:55:58] |
Yes this order type is supported with Transact. We need to see the error message you are getting. For instructions to provide this, refer to: Support Board Posting Information: Providing Lines From Trade Service Log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-19 13:59:01
| [2020-10-19 14:09:48] |
I am trying to test them, but they don“t work. When I place the Buy or Sell Stop limit Order from the chart I receive a message in the Infinity DOM (Error: Failed to Send Order) and When I tried to cancel the Order from the chart it takes a lot of time to disapear from the Chart. In Sierra Chart Message Log appears the following : TransAct WS Trading Information Cancel Request response: Fail |
| [2020-10-19 14:21:55] |
You need to contact Transact about this.
| [2020-10-19 15:07:03] |
FYI, that type of order is not supported by transact. As you can see in their response (attached)
