Date/Time: Fri, 13 Nov 2026 21:50:27 +0000
How do I change the color of the Menu and BE button
View Count: 1745
| [2020-10-19 12:10:23] |
| User967921 - Posts: 8 |
Hi Can you please tell me how to change the color of the "Menu" and "BE" button in the trade window. Also what does the "BE" Button do? I can change most of the button colors in the trade window by using this pathway: Global Settings > Graphic Settings-Global > Chart Trade Window > (Buy/Sell Button Color,Flatten/Reverse/Cancel Button Color, Quantity Buttons Color) but can't see the "Menu" or "BE" button settings |
| [2020-10-19 14:31:01] |
The color of those buttons cannot be changed. That will be supported later. BE stands for Breakeven: Basic Trading and the Trade Window: Main/C >> BE (BreakEven button) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-13 20:14:54] |
| User519569 - Posts: 18 |
Please do make the Break Even button color and font adjustable. Seeing and using this button quickly is an important aspect of my trading. Thank you in advance.
