Date/Time: Sat, 21 Nov 2026 10:47:38 +0000
Setting targets and stops based on study values
View Count: 1644
| [2020-10-17 17:01:01] |
| User406455 - Posts: 6 |
I'd like to be able to create bracket/attached orders based on the value of a study. For example, upon a limit order getting filled, I may want the stop set to the current moving average indicator value and the target some multiple of that. Is this possible? If so, where do I learn how to do it? |
| [2020-10-17 18:20:39] |
| Sawtooth - Posts: 4362 |
Use the Trade Management by Study study. Attached Orders: Study Controlled Targets and Stops |
| [2020-10-18 11:10:47] |
Yes refer to: Attached Orders: Study Controlled Targets and Stops Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
