Date/Time: Fri, 06 Nov 2026 08:36:54 +0000
no control bar for Scale Range: User Defined with Auto Set
View Count: 1007
| [2020-10-17 02:35:57] |
| User814219 - Posts: 38 |
Is there a way to add "Scale Range: User Defined with Auto Set" as a control bar tab or to the chart shortcut menu? I find it odd that you allow users to add "Scale Range: User Defined" as a control bar tab/chart shortcut menu but not "Scale Range: User Defined with Auto Set", especially since the latter is much more quicker and hence more useful. Date Time Of Last Edit: 2020-10-17 02:40:37
| [2020-10-18 11:01:38] |
Yes we will add this.
| [2020-11-23 06:50:28] |
any update to this? it'd be best to add Scale Range: User Defined with Auto Set to Chart -> Scale -> Scale Range: (Automatic/Independent/Constant Range/User Defined) so we could enable it via control bar, chart shortcut menu, or even keyboard shortcut. |
| [2021-09-08 18:05:30] |
| User753428 - Posts: 185 |
+1. Would be nice to be able to toggle Scale Range: User Defined with Auto Set via keyboard shortcut instead of having to right-click on the scale each time.
| [2021-09-13 09:35:20] |
| Sierra_Chart Engineering - Posts: 25390 |
Yes we will implement this.
| [2021-09-13 09:54:10] |
| User90125 - Posts: 715 |
+1
