Date/Time: Sat, 21 Nov 2026 10:55:39 +0000
[User Discussion] - Create Time string
View Count: 1125
[2020-10-06 13:40:22]
User681150 - Posts: 62
i want to create a standard chart time string 11:35:20 to output to the window log. i have this but cant concatenate to make it a string. can anyone advise how to.. the "time" variable keeps failing
int Hour = sc.BaseDateTimeIn[sc.Index].GetHour();
int Minute = sc.BaseDateTimeIn[sc.Index].GetMinute();
int Second = sc.BaseDateTimeIn[sc.Index].GetSecond();
SCString time = Hour+":"+Minute+":"+Second ;
[2020-10-06 13:54:45]
Ackin - Posts: 1866
i want to create a standard chart time string 11:35:20 to output....the "time" variable keeps failing
try:
SCString ResultText;
SCString time;
SCDateTime CurrentIndex = sc.BaseDateTimeIn[sc.Index];
ResultText.Format("%i:%02i:%02i", CurrentIndex.GetHour(), CurrentIndex.GetMinute(), CurrentIndex.GetSecond());
time+= ResultText;
[2020-10-06 14:38:22]
thats works perfectly. thanks you.
quick question. in your example. you put the Result variable into another variable using += ... why?
[2020-10-06 15:01:40]
Ackin - Posts: 1866
Just to show you how to work with the string if you want to combine it with something else. At the top (in your first post) you mix numbers with characters.
