Date/Time: Sat, 21 Nov 2026 11:03:40 +0000
ACSIL - Compilation issue - _vscprintf
View Count: 1174
[2020-10-05 17:32:21]
ejtrader - Posts: 689
SC Team - Trying to use Borland Compiler for compiling few studies one of the SC header files is failing with the following message.
[bcc64 Error] SCString.h(816): use of undeclared identifier '_vscprintf'
There seems to be a workaround to use a different function for this.
https://stackoverflow.com/questions/4785381/replacement-for-ms-vscprintf-on-macos-linux
I am able to compile using other compilers but not bcc64.
Usually if this was a warning - I can skip the warnings but it's actually erroring during the compile time. Other than header update there seems to be no workaround for this.
This is NOT a show stopper for me (as I can use other compilers to compile to code) - still would be be nice if this can be fixed as I would like to use C++ Builder as a tool which only supports Borland C++ :(
thanks
Date Time Of Last Edit: 2020-10-05 21:14:20
[2020-10-06 07:23:40]
You will need to work out your own solution for this. We are not going to get involved in this.
