Date/Time: Sat, 21 Nov 2026 11:03:51 +0000
Running Sierra Chart on VM
View Count: 1153
[2020-10-05 09:55:41]
User991052 - Posts: 33
Hi Support,
Could you please confirm the best method for installation when running Sierra Chart on a VM (Virtual Machine).
Q. Should VM (Parallels) be installed on a seperate SSD w/ Sierra Chart ?
Regards,
[2020-10-05 13:39:48]
We do recommend a separate drive for Sierra Chart. Other than that, what you do is up to you.
We do not know why you would involve Parallels. Are you not running Windows as the main operating system on the computer?
[2020-10-05 13:55:39]
Hi Support,
No, running Mac OSX hence the VM (Parallels).
Regards,
