Date/Time: Sat, 21 Nov 2026 11:03:42 +0000
Please prevent Sum Pullstack values from resetting to 0
View Count: 994
| [2020-10-01 18:56:18] |
| FuturesTradeKing - Posts: 13 |
I use the Number Bar Calc Value 2 through out my trading setup showing the SUM BID PULL/STACK and ASK PULL/STACK. Any time a change is made to the chart. Almost ANYTHING at all. These values reset to 0. For example I enabled coloring and they all reset. I changed the chart zone it's in, reset. So if I want to maintain these values to look historically for the day, I have to treat these charts like fragile children. Can you please just make the numbers persistent? It doesn't seem like a think such as changing color should erase all the data. |
| [2020-10-01 20:54:54] |
Not with the way they are implemented. The only thing we can do is just remove them altogether.
| [2020-10-01 22:11:27] |
Well that's not a good option. I guess beggars can't be choosers.
| [2020-10-02 03:29:15] |
| User542430 - Posts: 50 |
I find the pull/stacking one of the best features about SC, please do not remove them!
