Date/Time: Thu, 05 Nov 2026 13:26:16 +0000
Zig-Zag Study Color Scheme modification Request
View Count: 976
| [2020-09-25 12:24:35] |
| Sudhirc - Posts: 58 |
The numbers on the Zig-Zag wave are ASK BID Volume Difference. In most cases the up wave is positive delta it colors - green & in down wave in most cases it is negative delta & colors Red. In some cases where i circled, the up wave has negative delta and the down wave has positive delta. Can we have an option for the color scheme so that all positive delta's are one color (green) and negative delta are another color (Red) http://www.sierrachart.com/image.php?Image=1601036627740.png |
| [2020-09-28 09:39:38] |
You will need to make this modification to the code. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-08-17 15:08:23] |
Hello, any update on this request please...thank you.
| [2021-08-17 15:17:20] |
| John - SC Support - Posts: 48433 |
We are not working on this. It is something that you can do yourself by modifying the source code as noted in the previous posts.
