Date/Time: Sat, 03 Oct 2026 12:02:46 +0000
[User Discussion] - ACSIL method to re-initialise Subgraphs & User Inputs
View Count: 905
| [2020-09-19 05:31:19] |
| User553714 - Posts: 184 |
Hi, Does anyone know of an ACSIL method that clears all the Subgraphs & User Inputs to default values IE.. what occurs when you change a study input. sc.FlagFullRecalculate works to complete a re-calc but any values populated in a Replay and saved in subgraphs are not cleared using this method, the only thing I have found to work is by manually changing an input and pressing ok; I am wanting an ACSIL method to do the same. Thanks for any help. |
