Date/Time: Sat, 03 Oct 2026 12:02:08 +0000
Update version
View Count: 795
| [2020-09-14 16:33:29] |
| User681249 - Posts: 6 |
Hi, I have just updated new version. All my drawings disappeared. Please advice. I need them back. |
| [2020-09-14 16:54:56] |
| John - SC Support - Posts: 48095 |
The drawings will not have disappeared due to a change in version. Did you rollover to a new contract as well? The following documentation is most likely what you are seeing: Changing to a New Futures Contract Month: Allowing Lines and Other Chart Drawings From Other Contract Months to Appear on the Current Contract For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-09-14 18:49:31] |
Hi, It is same contract. Anyway chart settings was set to show chart drawings for different symbols. |
| [2020-09-19 14:20:20] |
I have downloaded previous version and drawings was back. Then again current version and drawings are still there. It seems to be solved. Thanks |
