Date/Time: Tue, 29 Sep 2026 21:43:02 +0000
Missing SCDLLName line at the top of the CPP File
View Count: 1591
| [2020-09-14 12:24:57] |
| jwick - Posts: 142 |
I just upgraded SC to 2164. After doing so, all my studies needed to be recompiled. Upon recompilation, I get the missing SCDLLName error message for all my studies. I haven't changed the code from before the upgrade to after. Here are the top two lines in one of my studies for example: #include "sierrachart.h" SCDLLName("OTDiv") |
| [2020-09-14 12:59:01] |
Well this is interesting. I copied over all the code from the file that was having the issue (the issue was happening in all my custom files), and pasted the code into a brand new file without any modifications. Here I was able to compile and load the dll without issue. The issue remains if I try to compile the same code in the originally named file. Very odd. The DLL being produced is of the same name. Merely changing the cpp file name (from the pre-v2164 name to a new name) seems to have an effect.
| [2020-09-14 19:16:57] |
Does not make sense to us but if you have it resolved that is the main thing.
