Date/Time: Tue, 13 Oct 2026 05:09:50 +0000
Es and Mes dom
View Count: 2004
| [2020-09-09 14:27:44] |
| User425645 - Posts: 123 |
hello, i am an /mes trader but am trying to execute on /es dom, is this possible? ill post a picture of what a friend recommended below but as you can see from my P&L the dom is still executing /es contracts. I want to soley buy and sell /mes on the /es dom. Thanks for your time it is much appreciated |
| Attachment Deleted. |
| [2020-09-09 14:58:31] |
| John - SC Support - Posts: 48184 |
What you are doing is correct, but to get the P&L on that chart to reflect the MES, you need to enter the Currency Value per Tick for the MES symbol and not for the ES. Refer to the information here: Chart Settings: Updating Currency Value per Tick for Trade Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-09-09 15:26:25] |
awesome thanks! so just to make sure if i do all of this it will be trading /mes contracts on /es dom right? and not just trading es contracts but with a changed tick p&l Thanks again |
| [2020-09-09 15:46:37] |
Whatever symbol is in the Trade and Current Quote Symbol field is the symbol that is sent to the exchange for the trade. Refer to the information here: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
