Date/Time: Tue, 10 Nov 2026 05:52:45 +0000
Specify version to upgrade to?
View Count: 863
| [2020-09-01 22:55:46] |
| User612901 - Posts: 25 |
Hi I am currently running v2138. Would appreciate you advising how I upgrade to a specific version eg 2146 (noting that 2146 is several releases less than the most current upgrade) Thanks in advance |
| [2020-09-01 23:31:41] |
| Ackin - Posts: 1865 |
Look: Software Download: Software Rollback Procedure Date Time Of Last Edit: 2020-09-01 23:32:45
| [2020-09-01 23:36:46] |
Only my recommendation: If you use third-party libraries (studies from someone other than Sierrachart), check" "for which version they have the latest update". Many changes have occurred in versions 2149/2151 and still many developers do not have an update available for versions higher than 2148. Date Time Of Last Edit: 2020-09-01 23:38:59
