Date/Time: Tue, 10 Nov 2026 05:52:49 +0000
Live trade markers/lines incorrect
View Count: 808
[2020-09-01 17:23:32]
User920967 - Posts: 65
Tried to search the board for a quick solution but could not find anything.
Essentially, trade markers were initially correct on entry and exit, however after some time the lines connecting the markers became incorrect. I contacted my broker to double check the fills and the original marker and lines were correct.
Not really sure where to begin correcting this issue, i did upgrade to latest version of Sierra and problem still persists.
Please let me know if you need any log files.
Thanks in advance.
[2020-09-01 19:09:55]
Refer to the information here:
Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities
[2020-09-01 21:39:37]
Problem solved, thanks!
